- Apr 21, 2013
- 209
On my Millport (Bridgeport 1J clone) that I'm working on, I recently started on the quill stop, only to discover many missing or damaged parts. I can make it work as a basic stop without too much work, but the kickout for the quill feed will require a lot more parts (expense).
My question is, do many of you use the kickout for the quill feed? I do have a boring head that I'll be using the feed with, but I'm not sure how much I'll need the auto stop.
Also, mine is missing the small shaft that goes through the top of the main threaded stop adjustment rod (which is also broken on top). I noticed in photos that the small cross shaft looks like it has "balls" turned onto it. What is the reason for this?
Some of the broken parts.
Thanks,
Jack
Thanks,
Jack
