Quick set up angle plate
Philco
Oct 3, 2011
233
I made this angle plate sometime back. I wanted something that I could just drop into the slots in the mill, bolt down & be ready to clamp something up & start machining without having to spend time squaring it up. The piece started out as a thick piece of angle iron that I found at the scrap yard. I welded a thick piece on the bottom side & machined it down
( file finished) so that it would slip into the tee slots.
The next picture is it mounted to the table image.jpg (847.4 KB)
The third picture is where I had it in use making a stop collar
I find myself using it more than the mill vise when I want something flat to the table & 90 degrees to the spindle.
Nice job Philco. Looks like it will serve you well for years to come. :thumbsup:
Nice job Phil, I have 2 of those I got from where I used to work. One I machined the 2 outside surfaces for use on my mill or surface grinder, the other I use as is on my welding table.
That looks like a nice set-up. Thanks for posting the photos. I'll have to keep my eye out for the right materials to build one.
Jack
