- Sep 24, 2012
- 498
I have a small project I want to put together, and it involves drilling & tapping in 1/8" x 1/8" square steel bar.
Looking at OnlineMetals.com, I have four alloy choices: keyway stock, 1018 carbon steel cold finish, W1 tool steel cold drawn, and O1 tool steel.
I plan to hand-file very small V-notches onto one of the surfaces. I want to do the same to two separate pieces, with drilled-tapped holes on both sides of the notches. The V-notches will hold the chucking end of a 0- or 1- sized tap, to prevent the tap from rotating while I hand-rotate the headstock of my watchmaker's lathe.
What I want to end up with is something like this:
My concern is avoiding deformation of the notches over time.
What alloy would you choose of the three I listed? Or will they all work equally well?
Will one of the alloys be easier to tap than the others?
Thanks.
Doug
Thanks.
Doug
