I'm looking to add a QC tool post to my Craftsman/Atlas 12" lathe. Am I right in assuming I will no longer be able to use all my 1/4" tool bits with the QC? Have to switch to 1/2"?
Thanks for any advice.
The qc tool post holders (assuming AXA for that sized lathe) will have height adjustment to allow you to get your center height set correctly. Scheck this out while mounting the tool post up.
Shim under the entire length of the tool. An HSS tool blank works well. make sure everything is nice and clean when mounting your tools, IE no chips/ or dust.
A 1/2" tool bit requires a lot of grinding; you would be better off using smaller bits, one can do a lot of cutting with 1/4" tool bits, and the Atlas is not such a lathe for heavy cutting that would require bits as large as 1/2".
I made an 8 pitch Acme external threading tool from 1/8" square HHS, let it into (cut a 1/8" keyway in the top of) a piece of 1/4" key-stock. It worked a charm and very little grinding, compared.
