- Feb 6, 2013
- 99
This took me a while to get around to this. So I used all my eyeball engineering skills to produce this little part. First out of the scrap pile I picked up a 7/8" piece of steel. It used to be a steering stem for a chopper. A bit of the rust was taken off to make it all shiny.
It was then cut down to length and turned down to fit inside the quick change post.
Then it was drilled and tapped for a 8 x 1.25mm thread.
Then drilled for a 3 1/2" x 1/4" rod through the center. I flattened it on one side with a sledge hammer and what Harbor Freight calls an anvil.
Here it is mounted. Not a bad addition to the lathe.
It was nice to figure out how to get a fine surface finish with this Jet BD920. Slowing down the feed and re-doing the cross slide helped big time.
