- Feb 7, 2013
- 28
I purchased a Bolton Hardware 10 x 22 lathe at the beginning of the year. I chose it because of the power cross feed vs others in the market as well as tumbler that i would have had to build with others. Plus the cost was lower at the time. But I had wanted a quick change tool post but due to the top slide design I would need to make big changes to it and they would not be reversable. So I decided on my own design since I also do like the multiple tool holder of the 4 position one that is included because at times just a rotate through tools on a single project helps. I designed a block that can be mounted into one of the the 4 way positions but is just like a piston style quick change post and I made 3 tool holders to go with it. Works great and I had all the materials on hand.
I made it out of mic 6 al and 12L14 steel for the cam and handle, made on my LMS mill, Taig and Bolton lathes. All metric hardware to match the lathe.
A side note if you consider Bolton I have had some issues getting parts from them so you might want to be cautious if you were to need them quickly.
