- Sep 20, 2012
- 560
Hi folks, first post since my introduction, a little bit of help needed if you would be so kind.
I've been cleaning the AcornTools branded q/c gearbox on my 10" Atlas lathe, I used a hand held drill bit to clean the muck and even paint out of the oiler holes for the shafts.
I noticed the holes seem to end above the bushes, with no apparent oil path to the shafts, so have the bearings turned and closed off the holes or are the bearings some sort of porous oil retaining type that the oil just seeps through?
Also there are no oil cups fitted, hence all the muck inside, are these tiny ones still available and if so do they need felt wicks if the bearings are porous?
Thanks for your time,
Bernard
Bernard
