- Oct 30, 2019
- 225
My wife picked up a few garden trowels from what she thought was one of the better brands ("Ames" iirc instead of the low end store brand stuff) in a local home center last year or the year before. You know, spending a few more dollars to find something that might hold up better over time in its construction or handles or something....
Well that backfired, all 3 had their weldment fail in the same way if you put a bit too much torquing load on them -- just not enough cross-section to the joint if not other design or process failures
My thought was to braze it - this is some kind of stainless alloy, which I am not set up to weld properly. But I can braze it and have that handy.
Cleaned up the first one and gave it a shot
Clamped
Not great, I think I got things a bit too hot or maybe had a carburizing flame that got in the way of good wetting. Or maybe my cleaning wasn't good enough (that cleaning picture above may be from the second trowel)
Second attempt came out cleaner.
Based on how much braze rod I flowed into the joint, I am optimistic that it did wet most or all of the mating faces between the two parts
That's all on this one, thanks for reading
Clamped
