Hey guys, I just thought I'd pass this along. A few nights ago, I was at the shop trying to get a parts list together for my old 12x36 lathe and trying to figure out how I could make/repair some of them. I came up with some ideas, then started putting the carriage back together and remembered that the cross slide nut was really loose. I didn't want to put it back together that way, so I got the bright idea to tighten it up. I used my bandsaw to slice it lengthwise all the way into the bottom part of the threads, then I clamped it in my vise to close the gap back up. I filed a V along the split and then brazed it back together, after test-fitting the screw. Afterwards, the screw was extremely tight due to a bit of brass that flowed down into the threads, so I used some 220 grit lapping compound and lapped it in. I don't know how long it will last, but right now, there is no discernible play in the cross feed at all and it's slick as glass. The whole process took maybe minutes and saved me over $40. )
