- Jan 22, 2012
- 655
I need to tap some 1/2-13UNC holes in steel. I have the 1.25" dia bar stock chucked in the 3-jaw and have drilled a 13/32" hole thru (1.25' total length of hole). I start my tap and 2-3 threads in the part is slipping in the 3-jaw chuck and get's to a point that I can't turn the tap handle. The steel is a mystery metal given to me and seemed hard when turning it. Should hand tapping 1/2-UNC be very hard to do? Should I open up the drill hole?
