- Mar 5, 2014
- 390
I just picked up a 14 inch lathe, Logan 6565. I have some general questions. This machine is much more complicated than my Logan 820.
1. It has a Hardinge J2 collet chuck with lots of round collets up to 1-3/8. I thought it was a 6C until I cleaned one of the collets. What is the difference between this and a 6C?
2. If this chuck is not running exactly true, is it adjustable and how do you do that.
3. Something is slightly out of balance, the lathe shakes. since the chuck is a relatively small diameter and symmetrical, I don't see what could be causing this.
4. The lead screw has some unusual wear on just the points of the lead screw on the spindle end. I wonder if a bolt head is rubbing on it. Can I buy a generic lead screw?
5. I can't find a motor reverse
6. there is a 30 second delay in shutting off the motor, doesn't seem very safe.
7. There is a very complicated looking collection of contactors that control the 2 HP 220 1 phase motor. Why?
Thanks for your help. This machine is a big jump for me.
John
John
