Questions about Mach 3 and USB
speedre9
Aug 26, 2013
167
Since Mach 3 is printer port happy and pin-outs are easily configured what are the issues when using a USB driver controller board. Is a harder configure or just not a good idea.
I use MACH3 with USB. The motor controller uses USB and has a MACH3 plug-in. It has and continues to work perfect. Now if you have a motor controller that needs a parallel interface and you are thinking of using a USB to Parallel bridge, that might be another can of worms.
I am in the process of assessing and choosing a new driver card. I have recently smoked one of my Geckos, I do not think I will buy another one, too pricey right now. So is a plug in or patch availible for USB operations from Mach 3? They are showing as a little cheaper than parallel port cards right now.
Is this was you were thinking about?
http://cncdrive.com/MC/UC100 datasheet/UC100 users guide.pdf
Did we have another thread going someplace on the Mach3 and USB setups? I just remember the monkey hanging . LOL. Anyway - I have the URL saved. I would not use this w/ a Plasma table but would on My Mill as others are noting it is a worthy product. (of course YMMV)
That may be but it's not mine. That add on looks promising but still pricey. I may have to wait some before I move on anything.
I have just converted an old RF 30 to cnc, and this time decided to go with USB (UC300) instead of the parallel port. I was under the assumption that the UC300 board was just "replicating" the functions of the parallel cable, but without the problems associated with parallel cables. I have to say that it was no more difficult to set up, and so far has performed flawlessly:allgood:
I have used the uc100 on several of my builds with no problems except one. It will not work with mach3 lathe in sync mode for threading. Threading requires a real time pulse from the spindle that so far I haven't seen in any of the Usb cards I have checked.
The uc100 or uc300 are a major improvement over just a parallel port and breakout board with a notable increase of speed and pulse clarity. the higher pulse rate allows you to use a higher steps per revolution setting and greatly increases the accuracy of the machine.
the breakout board I use with the uc100 has no Opto-couplers, they are not required because the uc100 has it's own. some of the breakout board Opto-couplers are very slow acting and will not allow you to use the full speed of the uc100.
with higher pulse per revolution settings you are breaking the inch or MM into finer increments allowing for greater accuracy.
My zx45 mill will step in .0001 increments and with accurate backlash compensation I can move my 300 lb mill head 2 ten thousandth at a time changing direction of motion.
I am not affiliated with the company but I did do several months of beta testing for them a year ago trying to resolve the lathe spindle sync problem for threading, It wasn't resolved and I don't use a Usb controller on my lathes.
hear is a video of me playing with accuracy
steve
[video=youtube;7wtMc__ez7M]https://www.youtube.com/watch?v=7wtMc__ez7M&list=UUrSzkRVoWrsaxbrYL4uihOQ[/video]
If you want to look at Mach4 there is a new board from PMDX.com that is USB and a breakout board. They are offering a package sale with Mach4 and the board. http://www.pmdx.com/PMDX-422
I did some beta testing of the board and it works very well. It does not support lathe threading, but there are indications that is in the plan.
Mach4 is a totally new program. It has most of Mach3s features, but is smoother, faster and just all around better engineered that Mach3. Lots of new stuff to learn, it has an embedded screen editor and uses lua for scripting instead of VB.
For Mach3 USB I have used the smoothstepper with good results. I have also used the ethernet version of the smoothstepper.
steve
Based on your response here and what you've learned since completing your CNC mill conversion do you have any recommendations on USB or Ethernet breakout boards? I'm asking because you said that the board that came with your motor/driver kit didn't have very good performance. I bought the same motor/driver kit. Just about got the mechanical conversion done on my mill and will start working on the electronics soon.
Thanks,
Tom S
Hi tom
I use the uc100 and the basic breakout board C13 from cnc4pc.com. the c13 is a direct pinout board no opto-couplers.
I have also use a powered usb hub so I don't have a low voltage problem powered usb hub.jpg
I have never tried an ethernet board.
steve
