I am the relatively new mini lathe owner. I am attempting to make a part that a friend of mine drew up. Not too complicated. all turning, no drilling, and no milling (which is good, cause I don't have one!). I don't have a machinist handbook yet (its next purchase) or I would try to look it up and figure this out myself.
Anyway, my question is this: I have a piece of 1.2" stock and I want to thread one end of it to 5/16-18. What do I turn that end down to before I try to thread it using a die? or before I try to cut threads with the lathe itself? would it be the same initial major diameter? Is there a preference to one method over another? How would a production shop do it? (I cant see a production shop not using a Die unless they have a CNC to cut the threads...) But I'm not production, I'm only making one of these (unless I screw it up) and I am learning... so I am thinking I will cut them with the lathe, and the 'chase' them with the die to see how close I was. (?)
ok, enough of my chatter... let the wisdom flow!
(thanks for all your help!)
