question on taper turning
irishwoodsman
Nov 19, 2011
966
my question is does the numbers change in the formula when your overall length changes even though your cutting the same taper at a specified length, in other words if i cut a mt5 out of a piece of bar stock 7 inchs long or a piece 9 inches long are the numbers going to change ty much mac:biggrin:
The taper per inch is constant, but if you're using the tailstock offset method, the total offset will be different.
Thank you Tony. that was a big answer for me, a matter of fact it had me stumped lol but i understand now, buy useing tail stock your tangent angle will change on work piece but by using the compound once it is set it cant change:thinking:
Right. You can't put a Morse taper on a 10 foot long piece with the tailstock. Compound, yes....but not tailstock.
but your taper is limited to how much movment you have on compound:biggrin:
I didn't answer this one, but yes, the larger the Morse taper, the longer it is also, so you may not have enough
travel with a compound. Same applies to Jarner, B&S, etc. You have to stay within the travel limits.
Yes i understand that, the biggest i would be turning is prob a 5mt which is 4-15/16 and i have about 7" of travel on my compound:biggrin:
