Hello all. I'll try to keep this short & concise. I also realize I might be (re)opening a can of worms.
Recently acquired a bridgeport vertical mill with step pulley head. Max rpm is 2720.
I have a nice set of USA made maintenance/mechanics length 135* split-point HSS drill bits that I like to use. I will eventually acquire some stub length bits as well.
I'm aware that spot drilling isn't totally needed with split-point drill bits, but I'd like to get some to use when I feel the need for it.
It's my understanding that I'd want a 140* or more spot drill for use with 135* drill bits (and 120* spots for 118* drills).
It's also my understanding that I should generally avoid carbide mills/drills in my BP, since it usually can't spin them fast enough, and they're fragile/expensive compared to HSS.
My question is, why can't I find any HSS 140* spot drills?
All of the 140* or greater spot drills I see for sale are solid carbide or carbide tipped.
All of the HSS spot drills I see for sale are only 120* or less.
What gives? What should I use?
Also, what diameter spot drills make sense for use with 1/8" through 1/2" drills? I figure I'll step up to anything larger.
Been doing a lot of reading online, but still can't seem to answer these questions.
Thanks in advance.
Thanks in advance.
