I have a cheap Chinese double piston (hand and air driven) hydraulic pump for a shop press that looks like this:
The piston with the handle attached is larger, for quicker movement. The piston with the air cylinder is smaller, so higher pressures can be reached.
In general I'm happy with the pump, but I'm having a weird problem with the pump.
When I want to lower the ram and I use the air driven pump it barely moves the ram then it stops and doesn't move it at all. If I pump with the handle it is fine. Also, once it touches the pressed object and I want to increase the force the air pump works fine.
Here let me say the system has been bled of air, and I tried both with the vent open as well as closed (with vacuum forming in the oil sump). It is even worse with the vacuum in the oil sump. In fact when I use the hand pump and I lower the ram half way with vent closed it too stops working.
By "feel" I can determine the problem is caused by the oil not having enough time to fill the pump's piston before a working stroke occurs.
With vent open if I pump by hand I can simulate the same condition by attempting to pump really fast (the air cylinder does maybe 4 pumps per second when it's lowering the ram). If I do that. I can feel the pump's cylinder is only half full. If I wait longer it fills it fully between strokes. With vent closed and resulting vacuum in the sump it is much worse.
I thought this is an issue of oil viscosity as the system came with oil that looked like 30 weight and I've added hydraulic 46 weight oil. So to lower the viscosity I've also added enough 10 weight spindle oil for the oil to become even less viscous than initially. It didn't seem to make much difference I can tell. Also it is rather cold around here. Approximately 3C or 37F.
Does anyone else notice this issue with this pump? It is a bit silly the air cylinder that is supposed to speed up ram lowering only works for actual pressing, not ram lowering and one needs to pump by hand to lower the ram.
Perhaps I have air bubbles in the oil? Otherwise, I can't think of anything. This system has sat unused for quite a while, but it was filled with fresh oil before. I doubt there is any crud in there.
Unless anyone has any tips how to fix it I'll have to drain it and check the insides. As it will involve repeating the whole air bleeding cycle again. I'm not looking forward to it.
