Working on a small project, and today a slight modification to the mechanism came to mind. So I pose this question: What is available (short of making from scratch, which I can, but rather not do) in the way of a low crack pressure check valve, on the order of working on a 6mm line, with a crack pressure or ~1 lb. While at the local Parker distributor, I asked about one, and they only offer a 5 PSI crack and I'm quite certain that is too high.
For a general idea of what I am building, it is a peristaltic pump driving a hydraulic cylinder. At both ends of the stroke, I want a safety in the way of a bypass so I don't dead-head the pump. I want to avoid complications such as an electronic solution where the current rise when the pump does dead-head. I could do that, but it's just added components to deal with, and more chance of breakdown. Plus, the possibility exists of accidental pressure being placed on the system by manual manipulation, so there should be a "safety" to prevent any damage from someone forcing the cylinder. The electronic solution wouldn't protect against that. There is not room for limit switches. Or if anyone has another idea, that would be welcome too.
