Question About Types Of Bridgeport Heads
markba633csi
Mark Silva
Apr 30, 2015
12,188
Haven't touched a Bridgeport since high school and am now trying to re-familiarize myself in case I see one in the neighborhood for sale. Did they make a model (or models) which can not only "nod" the head but tilt it from left to right also? I think the old 5" round colunm ones could tilt but not nod? And it seems the newer dovetail ram models can nod but not tilt? Someone straighten me out here- thx
Mark S.
Mt. View, Ca
Hi neighbor, I would not buy a round ram because like you said it can’t nod. The newer dovetail versions can move in both directions…Dave.
So what's up with this arrangement? (for sale now on Ebay) Mark S.bridground23.JPG
The dovetail BP can nod and tilt. At the same time also.
Round ram mills (I have a 1948 "M" head machine), can nod, tilt, and swing. In the picture above it is setup to tilt and swing. You have to turn the ram 90* to allow it to nod. In the picture, you can swing the head to the side then tilt the head, allowing it to artificially nod.
There are two ways to tilt the head on a round ram, using the worm gear on the turret casting or the front 4 face bolts that actually hold the head on.
If you have one of the round ram to "J" head conversions, offered from around 1951-53, (before and during early dovetail bases) you don't have a knuckle. In that case you can only tilt the head.
Round ram machines don't have a worm gear to nod them. If you loosen the knuckle bolt there is a safety pin to hold it in place, but if you remove that the head will fall. Make sure there is some boarding under the head to keep it from falling. (Stack wood between the table and head, lift knee to apply some upwards pressure, remove safety bolt, loosen knuckle clamp bolt, lower knee to tilt head. At some point the head will slip off the table and crash, be very careful when nodding)
Ahh thank you Andre, now it all makes sense
Mark S.
My 1941 serial BH-663 (with the 1998th M head attached 'M1998') is exactly the same, nod, tilt, and swing. Some of the early J heads mounted on the round rams could only tilt and swing as they didn't use the knuckle.
John
