- Mar 27, 2022
- 509
Hey I have a mini lathe and milling attachment. I am going to make an endmill holder out of a mt3 drawbar blank. I understand the limitations of milling on the mini lathe and if any thing this will just be an exercise at making a tool and the "idea" of milling. So I plan on drilling undersize in the mt3 blank and boring to 3/8(the size of bits I have). I plan on mic'ing the bits and machining the holder to a "precise" measurement to help eliminate the bit moving to the side when clamping with the set screw.
I have a few questions for this project,
What clearance should I shoot for on the hole? I feel like I could possibly get the bit stuck if it's too tight and it tries to spin a little.
If that is a possibility could I drill a smaller hole through it so I could insert something on the draw bar side to press out? I dont know if I will have a hard time once it hits the hardened end.
Last question is should I harden the end after this work or will it's annealed state be fine for this operation? Also I have used oil, oxy ace torch and could round up sand. I haven't hardened anything since highschool so I dont remember the exacts of it.
Thanks in advance.
Thanks in advance.
