Don,
I would imagine that you can adapt a qctp to your smithy without any major re-work to your cross-slide. Most of us with old iron use some sort of "T-nut" arrangement to hold our tool post because that's what our lathes started with, but that's the only reason and really doesn't provide any benefit.
If my memory serves me right, the smithy has a 4-way tool post bolted to the cross slide, correct? If so, you should be able to remove the bolt and tool post, and mount your new one. The only thing you may have to do is adapt either the bolt (get a new one and mess with it, then you can always switch back if you want to) or making sleeves/spacers etc if the existing bolt diameter is smaller than the hole in your qctp. What diameter/threads currently hold down your tool post? We can better help you from there.
To answer your question though, I would go with AXA. You may also wish to look at the KDK style holders. I have one and prefer it to the aloris design, but it is only personal preference.
