QCTP machining the nut?
Tamper84
I am about ready to order a qctp for my lathe. In the ad it says I have to machine the nut to fit my what? I'm guessing they mean the nut that goes in the cross slide. Well if I need to machine it, it will be the only tool post o have and no mill. How would you do it?
Thanks,
Chris
Yes, machine the nut to fit your compound slide, assuming you have a slot in yours instead of a threaded post. Since the dimensions will vary from machine to machine, the T-nuts almost always come blank & will need to be machined.
I was in the same boat as you, no mill, so I sent it to a fellow member of another forum to have it milled for me. I'm sure someone here could help you out with that or you could try to find a local machine shop in your area.
Another easier way out is to make your own T-nut but in a round shape so it can be made on the lathe. But that may or may not work depending on your compund slide. Be sure to machine the nut so the top surface sits below the surface of the compund slide, otherwise you will never be able to tighten down your QCTP.
Thanks,
Chris
I would think they are talking about the T-nut that slides into the compound T Slot where the Quick Change Tool Post connect to the lathe. It has nothing to do with your compound screw.
Dark Zero.... GMTA lol.... at same time
It seems to be nearly always necessary to machine it to fit the T slot in your particular lathe. Making the nut fit the T slot as fully as possible will also help against jerking a hunk out of the T slot accidentally,because it has the maximum surface bearing on the T slot.
It helps a lot to make the center of the nut T shaped as shown in the above picture. It makes the nut thicker,so it will tend to bend upwards less under pressure,which can also cause your T slot to become cracked or broken. I advise against making the T nut round as it will be exerting force on a much smaller portion of the cast iron T nut,which possibly could lead to a broken T nut. The cast iron on Asian lathes may not always be of the strongest quality,so don't tempt fate.
It is also a GOOD idea to take a chisel and damage the threads at the bottom of your T nut,so the bolt can't screw all the way through it,and start bearing down on the compound. That can erupt the T slot. I've seen a few abused old milling machines with big hunks jerked out of the T slots in their tables by operators who did not think of that. If you have a clamping set for a milling machine,look at the bottom thread in the T nuts. They will have a big nick,or some damage to keep the bolt from screwing on through and bursting out the T slot.
I hope what I wrote makes sense. I'm tired.
Edit: I just saw in the "A nice surprise on san Aloris tool post" thread,that just the "boss" was machined on a T shaped nut,leaving the bottom part in full 100% contact beneath the T slot in the lathe. I see no reason why this method would not be satisfactory. I had been envisioning making the whole nut round,which would be weaker.
This has come up before, and one method used successfully if you have a 4 jaw is to chuck it and face down to a diameter slightly less than the top slot width, and deep enough so that the base fits the slot in the compound. You still have the thread length, so you aren't losing any appreciable strength. I'll see if I can find the thread. There were pictures.
No mill needed.
What lathe do you have? You can send it to me if you can't find some locally. Just cover the postage. It take 10 minutes. If it's not the same lathe as mine or any of the PM lathes, tell the me the exact dimensions you need. Will showed you a good picture of what's needed.
PM offline if you need to.
Thanks,
Chris
I couldn't find the thread I was remembering, but this one did discuss it a bit. Did I understand that you have no tool post at all for your lathe? If that's so, then your options will be more limited. Either drill/tap a thick enough plate to fit the slot, and be gentle so you don't fracture the compound and turn the new one as I described, or you'll have to find a kind soul to help you out. I'll do if for you too....so take your pick. I have a square turret type tool post I'm not using if you need it, but it's off a 17" swing machine, so might not help.
http://www.hobby-machinist.com/showthread.php/9635-QCTP-Base?highlight=tool+post
When i did mine, I had no mill, and i didn't even think it could be done on the lathe. I scribed it out with some dichem, I then hand cut the slots close on my band saw and fine tuned it with a file. It could also be done with a hacksaw in a vise and then filed it in close.
I lucked out on mine (sort of).
The nut that came with it was rectangular, and fit my compound in one direction. It was just too thick.
Chucked up the nut with it's own shaft sticking out of it, and just faced it down on the lathe. Done!
