- Nov 16, 2014
- 56
Hi, guys. I have a Wards 04-TLC with a Phase I I AXA toolpost mounted on the compound. I bought a set of 1/2" insert holders from Grizzly to use with it. But the cutting points are too high. With the AXA holder at the lowest setting, the points are about 1/16" above the centerline of the spindle. I expect I can exchange the insert holders for the 3/8" size, but I'd like to hear other options. I'm wanting to keep the 1/2" insert holders because I think they will be more rigid. Am I fooling myself, there? Would 3/8" be just as good? Can I mill the bottom of the insert holders or the AXA holders to make them sit lower? Is this a previously solved problem?
Thanks in advance for comments.
Regards,
Leon
Regards,
Leon
