That works. A tad high, perhaps, but it should be just fine on that lathe. Be sure to stone the top of the compound flat. The old lantern style posts sometimes leave dingle-berries on the surface. Found that out on my Logan early on when I switched to the Hardinge QCTP.I picked up one of the $30.00 JinWen QCTP's off Amazon for my 109. I milled out a full width t-nut for it and locktited a stud in place. It seems to be a copy of the A to Z cnc tool post which is no longer made. It's no Aloris but it should be fine for what I plan for this Lathe.TJ
Hey Craig , I have plenty of clearance , I know my Atlas 10 inch It has to be milled down slightly but my Atlas/Craftsman 12 doesn't because it is cast different to increase the height. In order for the OXO set to work on my 109 I would basically have to mill the whole compound down to the base of the T- nut slot and use a stud to mount a Tool post the JinWen drops down far enough but you do have to fit a longer stud on the tool holder to be able to fit the lock nut on the height adjustment.I didn't want to make any permanent changes to the machine until I know for sure I am keeping it. TJAre you able to rotate the QCTP on the compound (say when you want to check centre height with the tailstock)? I bought a 0XA set and the corner of the post would hit the casting on the compound. All I had to do was cut/file away a tiny triangle from the corner of the toolpost and then it would work.
Craig
