Ok thanks guys I am going to go with ths BXA. Next question any opinions on Dorian ,Aloris or an import. Are Dorian and Aloris that much better than the imports considering the big price difference? What is everyone using?
I have a DTM AXA set made in Clifton NJ until somewhat recently. Some guys who used to work for Aloris started the new company. They just retired, and someone on a Ebay bought out his stock and sells it.
I had a Phase II wedge style post which I worked just fine, and I believe would have continued to. I knew someone selling this DTM unit which I had already ogled at his shop.
The fit and finish, and operation are so smooth and positive. I know if I was making heavy or interrupted cuts, this thing would stay locked. I'll let you know if I'm wrong.
I have also noticed there are features and tolerances that you may not appreciate or know about until you are working with it either. This DTM unit has adjustments on the bottom to change when each wedge engages. Nice design.
If you can go USA-made you will never be sorry, as long as you can afford it. Or be patient and keep your eyes on Ebay, or post the "Wanted" sections of this and other sites. You will likely find a used set, perfectly operational, for almost the same price as an import set.
If you go import, I would suggest a more reputable brand like the Phase II or other. You will be perfectly happy and still get years of service.
Last option is to get the import set and just upgrade the toolpost later when you find one. This is what I did. The holders swap right over. Now I have loads of holders, some DTM and some not, and the post I really wanted.
Bernie
