QCGB lever 10-1586
rslaback
Jan 24, 2024
2
I have a gear box on the way for my 101.07403 which is going to come with a broken and incomplete right handle lever. Some preliminary searching has found at least one home machined copy for part 10-1586. I'm not afraid of that as a project. Would anyone happen to have even a preliminary sketch of the casting that I could use to machine out a part?
Picture/project credit to @Wierd Harold.
I don't think that I ever had the drawings for that assembly . I would suggest that you at least call Clausing and see whether or not they have the part or parts that you need, If they do, you can decide whether or not to buy it/them. If they don't and they don't intend to order it or them, they should offer to send you the necessary drawings. In the latter case, please also send me a copy of the .TIF or whatever drawing(s). I will clean it up and put it into Downloads.
Couldn't you use the left hand lever as a model?
You're right that I can. I had assumed that they would be different when I posted this but did notice shortly after that the parts breakdown has them as the same part number.
