QCGB Gears Orientation Levers???
Kroll
Dec 23, 2012
1,307
Well I thought I took pics of every part and from different angles but I have hit a snag.Looking at the pic the Left Lever 37T gear,Rt Lever 45T gear.Question--Pt#10-1553 20T gear is for the Lt lever and Pt#10-1512 20T gear is for the Rt lever,one 20T gear is larger than the other 20T gear which gear goes w/ the left lever??? I can't tell by looking at the diagram,but it looks like the larger goes w/the left lever.Just started and I'm lost,thanks for some direction---Kroll
Looks like they are pictured correctly. The large gear won't fit on the wrong lever and the small gear won't mesh correctly on the wrong lever with the shaft installed.
Steve
Poot,that makes sense.Thanks I'm embarrassed---Kroll
:)) Glad to see I was not the only one scratching my head over this the first time around!
