- Dec 11, 2013
- 302
So sometime back I purchased a QCGB-42.
It was in so-so shape not good but clearly not bad, lot's of potential for the right price.
When I went to look at it it was mostly covered in dust bunnies.
It was in a auto repair garage in Manhatten, NYC and they clearly had no idea how to run or what to do with it so it ended up on CraigsList.
It was missing the Tailstock (no big deal I already had a TV-32 10-F so I was good with just moving that over)
The QCGB was jammed up tight but a look up under and behind with a flashlight showed it was packed with chips that were bindging in the gears.
It had a nice condition 3 Jaw 8" Chuck with reversible jaws, the Lead Screw showed almost zero wear as did the bed rails.
So I pulled the trigger talked them down to $250 and it went home with me.
I figured the worst that could happen was it got parted out.
Well, life and all it's stuff 2-1/2 years later I'm finally getting around to putting it all together.
I sold a house, moved into a rental, built a house, and prepped out a new expanded work shop since i brought it home..
I picked a few of it's missing parts along the way., and started doing a dry run assembly to check it all over.
Today was mount the headstock & QCGB and a clean up of the CounterShaft.
The one with the Grease Caps that get tightened every so often to squeeze grease into the roller bearings.
The grease was so old and dried up I had to use a drill bit held with vise grips to drill out the old packed in grease. It came out in brown dried up chuncks.
That's why I'm saying getting there slowly might be a good thing. I hope to clean this up right.
I've got a working lathe the old TV-32 10-F I'm not forced to hurry along to get this one up and running.
I'm also wondering how many of these might be out there with old packed in dried up grease that prevents anything from getting to the roller bearings.
I probally should have taken some pic's (I know we all like pic's) but it was just a rainy day so I went to the basement and just started in on it.
I'll try and get some stuff up as I go along but no promises
I'm bad about remembering to take a camera with me .
I've got a long way to go but.. it's the journey right not the destination.
