- Dec 21, 2017
- 12
So, this happened....
I've been working on getting an Atlas 10" lathe back into running condition after it had suffered from a tip over and sat basically unused for over 20 years. I had just finished cleaning some gummy deposits out of the gear teeth in the headstock and back gears with a brass brush and thought I’d check the freedom of rotation with the back gear set engaged. I pulled the locking pin, engaged the gear then manually turned the headstock through a few rotations using the chuck. It moved easily with the exception of one slightly tight spot. It rotated through a little easier each time, so I returned to the original configuration. Then to my horror, I spotted a chipped tooth on what was before a basically perfect gear. And then...utter despair when teeth started dropping off one after another.
I've got a replacement part on the way and have been reviewing the spindle removal procedure on YouTube. I'm fairly confident I can get the replacement part in, but the larger question is: Why did this happen in the first place? I really don't want a repeat occurrence.
I'm hoping some of the members here might have some ideas or thoughts on the subject.
- The bull gear is the only one out of the four that has any kind of damage (naturally).
- I'll be looking at the engagement mechanism a little more closely today. Seems like it's a pretty tight mesh when engaged.
- Is it possible that the Zamac material could have degraded? If so, there's concern for the whole machine.
- I'm having a hard time believing that something could have been bent (vs broken) in the fall, but will also look into that.
