- Apr 12, 2013
- 562
The larger of the 2 gears on my headstock floats L-R a bit on the spindle. Eventually it moves far enough away from the cone pulley that the direct drive pin pops out. I can worry it back against the 4 step cone pulley and all is well for a few weeks.
There is a set screw on this gear. When I tighten it down, the spindle locks up. Back gears do NOT need to be engaged for this to occur. Should this set screw be left loose or is there something else going on? I know about the cone pulley oiler...this is NOT that set screw. This is on the right side of the larger headstock gear, the same gear with the direct drive pin.
