So my 1228 should be here (fingers crossed) the end of next month and I am in the home stretch of getting the basement set up. Though I am no stranger to using tools, this is going to be the first time setting one up, so one question I do have is related to leveling the lathe. I have watched videos and know that I should be using a machinist level, the issue is there seem to be multiple types. I have seen some such as the Starrett 98 with the cast iron base and the 'exposed' tube and also some that are noticeably less expensive, appear to be spec'd for better precision, and are labeled "Master Level" or "Precision Level" that appear to be enclosed in a housing with adjustment screws.
Is one type preferable to the other? Is one easier to use?
I want to get the tool set up as best I can but also don't want to waste money on a tool I will not need very often once everything is set up.
Thanks
Thanks
