Hi Guys,
I am looking for some advice debugging or replacing the motor for my RF45 clone milling machine.
The motor on this mill has started stalling and popping my 20A, 110AV breaker upon startup. I have already replaced the start and run capacitor with no change in behavior. I have taken the motor apart and the start circuit clutch looks fine and nothing looks obviously shorted internally. The motor ran fine for about 40 hours of light use, but now stalls and blows the breaker 90% of the time. With the motor power circuit disconnected the magnetic switch circuit does not overheat or pop the breaker.
The electrical circuit for motor power shows melted insulation and very discolored clear insulation which makes me think the current is much higher than expected.
I am out of ideas for things to test and I would like to get running again soon to finish a few projects. I am open to more testing suggestions or suggestions for where to get a replacement motor.
I would like to stick with 110AC so I can using my existing shop power. I am open to the idea of using a 3 phase motor with a VFD if it is not cost prohibitive.
These are the critical motor dimensions in mm (AFIK)
And this is the motor plate
Any comments / suggestions appreciated.
