So I have been fighting a lot of issues with this lathe so I decided to give it a little bigger footprint. All that weight comes down on a little 8 1/2"x10 1/2" square on either end. I could not get the wiggle out of the lathe so I had to do something. I got the idea from others here on the forum. I had a friend at a local fab shop whip me up some 30" feet. The inner tubes welded on the sides will get caster wheels so when I need to move it when my shop is built I can wheel it to the basement door and into the shop. Also when I need to clean behind it or while I an converting it to 3 phase I can move it around with ease. I have jack bolts for the inner sides of the bases so I can support them as well. I just need to make some pads to go under them. I may order some hockey pucks depending on their dimensions. Granger also has some nice leveling feet so I might go that way also. Anyway, thanks to everyone on this forum for all the great information and the willingness to share it. Have a good weekend.
