I found a monarch that has been partially dis assembled it was used in it's previous life to turn motor commutators. Minimum owner will take is $1000
It has taper attachment, 3 and 4 as well as dog chuck and collet closer and collets. Advice appreciated. here are some pics I'm driving 700 miles in the morning to look at it. Bob
Obviously you recognize that there's a lot of work involved in putting this old girl back together. That said, $1000 is OK for what's in the pictures. If worst comes to worst, you can sell the tooling, part it out and come out OK.
This was an ELSR (Electric LeadScrew Reverse) machine. That’s a sought-after option.
What I'm not seeing in the photos:
- Feedrod
- Cross-feed dial
- Taper attachment draw-bar
- Apron sump (oil pan)
- Apron pump
- ELSR control rod and related stops and levers
- Collet closer draw-tube
If you're missing something like the cross-feed dial, you would have a real problem. I don't know if you'll see this before you finish there, but you'll want to take your time and make sure that you get ALL the parts and have an agreement that the seller will look for any missing parts that he may have once you get her home.
On the plus side, it's well tooled
- 3-jaw chuck
- 4-jaw chuck
- 5" dog drive plate
- 10" face plate
- Steady rest
- Follower rest
- Collet nose and about 40 collets
The above is worth at least $700, depending on condition. Check the backs of the chucks and the bottoms of the rests, if they are stamped with the machine’s serial number you have original tooling (it's unusual to see original tooling and a full set says a lot about the kind of care the machine had over the decades). The machine’s serial number should be on a rectangular plate on the base, under the tailstock end and is also stamped on the right end of the tailstock flat way.
Don't worry about the motor/generator drive. They are very reliable and robust. What problems they have tend to be minor. I've helped a lot of guys get them running.
Good luck and have a safe trip!
Cal
