Gary,
Unfortunately, the photo wasn't taken at the best angle to show this and the available scans of that photo are nothing to write home about. As I said somewhere else yesterday (or thought I did), no 6" parts list I have ever seen shows any motor mounting bracket. You mount the motor to the bench somewhat forward (toward the front of the lathe) of the countershaft bracket. From the geometry of the setup, the best compromise location for the bracket would be with the countershaft hanger (the part that attaches to the bracket and that the countershaft bearings mount in the jaws of) leaned forward about 40 or 45 deg. when the spindle belt is tight. Then mount the motor so that its belt is also tight. At that position, when you rotate the hanger forward with the tension lever, the pulleys move forward and down about the same amount. I don't know why Atlas never did a drill template for the A-suffix bracket.
Robert D.
