- Aug 4, 2023
- 78
After making a set of vise jaws using only an end mill for facing I've decided to make a fly cutter as my next project. I started with 2" round bar of mystery metal which I assume is probably cold rolled steel.
I cut a piece off about 3 1/4 inches. After facing it off came the arduous task of turning the 3/4 shank on my lathe.
This metal was very stringy. Using a carbide insert, I played with my feeds and depth of cut to try and manage the chips. I found that .025 depth of cut and cutting fluid made it manageable, and I stopped the cut often to clear out chips as they built up. At one point I tried .040 DOC and the workpiece came loose from the chuck. I had to reseat it in my 3 jaw and spend about 15 minutes trying to tap it back into concentricity. I got to .001 runout in 3" and continued to turn it down.
After a couple hours of work I ended up with this. The shank is .751 and 2" long. Fits right into a 3/4 collet. Surface finish is very nice. Tomorrow I'll move over to the mill.
I'm really enjoying the process of learning my machines and using them craft things that I can then use to create more.
