I am fairly new to machining - i picked up some scrap bar to practice on. The
place where i purchased it from said that it could be cold rolled. When
milling, it seems to leave a less than desirable finish to it. I am using HSS
end mills and even though i take off about 0.005 to 0.010, it won't cut very
well. I have tried to change mills, but both were new out of the pack. It
seems that if i mill it slow, the metal has the appearance of melting with globs
along the cut line. If i mill fast, it seems not to cut.
I am thinking about purchasing an indexable end mill, but others say that it
will chip when it starts cutting? Can anyone take the time to explain why this
is happening.
From others on this site, i see that they bore holes thru 1/2 steel and i can't
cut anything.
Another question, what do you cut stainless steel with? If i wanted to turn 1
inch square bar to round flatten 1 inch on both sides to make a tenon, and bore
a 1/2 inch hole in it, what should i use to do this.
is happening.
cut anything.
