I purchased an ER32 collet chuck and threaded back plate from a reputable company. I followed the instructions on how to fit the plate to my lathe, but when I installed the chuck there is almost .007 runout. The chuck fits well to the plate, I can't wiggle it when they are mated. I did need to enlarge one of the mounting holes on the plate because they did not match well enough with the chuck (the holes on the chuck are threaded, the holes on the plate are just counterbored clearance holes). The x axis runout is excellent (simple facing) but an indicator on the collet taper shows the mentioned runout, as well as visible "wobble" on all the untouched (by me) surfaces. This bothers me because before I turned the mounting surface of the plate, I installed it backwards and faced the backside surfaces to eliminate this wobble (purely cosmetic, but I did not want to see it). Then I removed it from the spindle, turned it around and proceeded to machine the mounting surface. It was at this point I noticed the previously machined surfaces on the back are not concentric and indeed wobble. (??) Though I don't think this should affect the front surface after it is faced
Is it possible that the spindle threads and the chuck mounting holes on the plate are not concentric to each other? Does the runout come from the chuck mounting bolt holes or the spindle threads? If the spindle threads are somehow out of alignment with the surfaces of the plate, I assumed a back and front facing would true it all to my lathe.
My next step would be to remove the bolts, rotate the chuck and drill new mounting holes, but I am not sure how to do that in a concentric manner (compound slide drill and tailstock center?) Before I try this, I wanted to see if I missed something, or if it is possible the plate (or the chuck?) is defective.
FYI this is on a Maximat 7 in very good condition, so I know the runout is not coming from my spindle or its threads.
