I recently purchased a mill and am doing a simple project to get acquainted with it - a vise jaw stop.
I successfully milled the jaws to size within .001” in all dimensions which I thought was pretty good. Each jaw has three holes - one for the screw and two for the guide rods. To locate the center hole for the screw I used an edge finder to locate each edge and divided in half using my DRO. The numbers on the DRO during this process matched my expectations. I drilled the center hole for the screw and then used the incremental mode to place the holes for the guide rods equally on either side. I used a center drill to spot each hole before drilling. The same process was used for each jaw with the inside face of the jaw facing up.
Here’s the problem: When the jaws are assembled with the screws and rods they are slightly offset by about .010” - easily noticed with your finger. However if I assemble them in the same orientation that they were drilled (inside faces in the same orientation rather than facing) then everything matches up perfectly.
So obviously the holes are not properly spaced in the jaws which I confirmed by measuring each jaw - they are offset by a few thousandths. However I’m confused since I thought the process I used should have ensured that the holes were centered. I could also understand some “newbie inaccuracy” but since both jaws are identical in the orientation they were in the machine seems to indicate that something else may be going on.
I doubled checked my DRO with a dial indicator and it seems to be reading correctly. I also practiced edge finding with a 1-2-3 block and was able to get the results I expected on the DRO.
I’ve made two vise stops and have had a small offset both times. Any thoughts on what I might be doing wrong? Quite possibly an operator error...
