- May 27, 2016
- 3,479
Let me say that I know very little about gas welding, but before even I try, I need to ask about the fuel gas.
SGS now seems to supply "Pro-Fuel" cylinder, with separate oxygen cylinder instead of Acetylene.
The claim is that acetylene primary flame is 3100°C. Pro Fuel is lower at 2950°C, which compares to Propane at 2600°C.
I understand Pro-Fuel might be propylene.
The claim is the pro-fuel secondary flame burns "twice as hot as acetylene" and is "much safer" to use.
Concentrating on the temperatures (and maybe "safety") might leave open how good it is for welding, as opposed to brazing or cutting.
The counter-claim is that acetylene secondary flame combustion uses oxygen from the surrounding air providing a "shielding effect" that does not happen with propane, nor any of the acetylene substitutes. Apparently, you can't get a reducing flame focused weld, and all welds are oxidized. There also seems much issue about changing fuel nozzles to suit other fuels. For some, there is no substitute for a proper oxy-acetylene rig.
I get it that these things get very technical, very quickly, and should not be what concerns one like me, who has not done gas welding/brazing/heating, but for me, it affects the decision on whether I try gas flame stuff at all!
SGS are the supplier I preferred for my MIG Argon/CO2 bottle, because they do not have a recurring hire charge. One bottle deposit, returnable, forever!
It is a disappointment they don't also do acetylene any more.
