I have one of the popular Harbor Freight 12-ton shop presses. It's a simple tool, but every few years the hydraulic jack begins to seep oil and eventually fails.
I release the valve, let the springs pull the jack closed, up against the crossbar, then close the valve. The springs put continuous pressure on the jack, but it's probably in the 20-30 pound range. Is this the likely problem, or are the seals on the Chinese jacks just bad?
