- Apr 24, 2022
- 182
From time to time I find that it would be quite handy to have a precision ground pointy tool that could be chucked up in a mill or lathe and used for locating or other setup uses.
Is there something available that is akin to the pointed edge-finder tool below, but solid with a rigid tip instead of the spring loaded tip?
I realize I could turn a taper on a piece of drill rod and grind to a point with a tool post grinder, but if something is available for a few bucks it would be well worth it, knowing it is concentric and hopefully hardened.
Thanks in advance.
Thanks in advance.
