Precision drill grinder
Looks good ...... What grit wheel are you using?
100 CBN and the finish looks good. Making the arbor and getting the wheel to run as true as I wanted took me more time than I expected. Part of the problem was my grinder thread was about .050 undersized so I had to make a special nut to custom fit the thread, then blue it in for fit. Jack
Looks good. Did you build the point splitter to go with it?
No, I only plan to use it for smaller bits and I'm happy with how they perform so far. Jack
