Powermill kondia (Bridge port clone)
Ropata
May 24, 2016
165
I'm finally doing the bearings and cleaning the top half of my head and have come across a strange grub screw on the front step pulley20191009_202201.jpg20191009_202153.jpgis this also on bridge ports or does anyone know what they are? Also does anyone make a good adjustable pin wrench?
The inner ring is #3 which holds the inner race of bearing. Middle ring is #4 which holds the putter race. The screw in question could just be a lock screw for #4 so it can’t back out??? The housing has two set screws #10 that lock the guides for the hi/lo lever the guides are #32. I do not see those setscrews in your housing??? I would guess the screw in question is just a lock screw. A pin spanner wrench can be had just about anywhere. Google
Hi, Wondering if you could help me On my Kondia G mill ?? With a wiring question.. do you know the wiring configuration for the 9 pin 440v to 240v so that I can get it running at home??? Thanks.., ps Even sketches to I’m pretty visual that way
This is for 220
This is for 220
Thanks thanks for the clarification so it looks like I don’t need to move any jumpers in just make sure all the wiring is in the same location or less coming out of the plug thank you so much this makes it a lot easier to hook up rotary phase conversion I purchased them in yours off eBay but didn’t really explain too much only thing I found out is that the mills are 1 1/2 hp heads and pretty much everything else is like a Bridgeport I really knew about. No your question about those bolts with this ever resolved or the screws? If not believe it or not Harbor freight security all sorts of the little nifty spendable wrenches and tools like a bit set that’s where I got mine and they were great to unscrew these little screws at the bottom of the headstock spindle…Thank you once again
