- Jan 5, 2014
- 995
I have a 16x40 lathe. The manual carriage feed wheel action is quite course so hand feeding consistently is tough. Also, like many lathes, the Z stop does not stop the power carriage feed so if I lose concentration and crash, the gear box will suffer. So, I was thinking about doing a semi-cnc conversion on this lathe. It seems like it would be easy to do so I must be overlooking something. Here are my thoughts. Disconnect the feed rod from the gearbox (but not the threading lead screw). I can actually do that with just a gear box setting. Put a servo motor on the feed rod. Put an encoder (MPG) somewhere for human input. Put in limit switches for crash and machining stop positions. Put in a means of setting feed rate electronically. When I want to feed, I would just manually operate the cross slide in the normal way, set the feed rate and engage the feed rod (or I could use MPG to feed "manually"). When I arrive at the machining stop point, the feed servo could automatically stop. I can then manually retract the cross slide, rapid feed the Z back to starting point, etc. I don't want to put the servo where the carriage wheel is because it would stick out too far. The mechanical threading capability would remain intact. What are experienced CNCer's thoughts on this? Has it been done?
