I have recently rebuilt a Bridgeport 6F-B power feeder. Today I worked on getting the table/ lead screw/power feeder installed. The one thing I couldn't check through this whole process was the length of the lead screw. I went with some internet information and had it cut to 36-1/4" total length. Turns out it is too long. The lead screw bottoms out on the power feeder shaft before the mounting bracket on the power feeder gets to the table. When I tighten the mounting bolts there is bout an 1/8" gap. I guess too long is better than too short
So options - I see two. A spacer between the power feeder mounting bracket and table or (the right thing) pull the lead screw back out and have it machined to length and, likely, recut a woodruff key slot. Unless something has another bright idea I'll probably pull the lead screw. I'm not fond of the spacer idea
Assuming I fix the lead screw - the one question I have is should the lead screw bump into the power feed output shaft or should there be a little clearance between them? My thought is too take about 1/4" of the length?
Thanks for your thoughts
Rick
Rick
