- Nov 14, 2014
- 851
Hello All,
My Bridgeport clone Servo 90 table feed(right hand side drive) lost its power cord yesterday. One of the wires pulled loose from the bottom of the housing.
Originally thought this was a model 140. But found a plate showing Model 90. Initially It wouldn’t come apart, but today found a retaining arm that screws into the inside of the housing. This has to be removed to pull the assembly out of the housing. Then Initially I thought the Servo motor was pressed into the bottom mount, and couldn’t be removed. So looking for advice on how to disassemble and rebuild.
But just now found a diagram on line showing two sort of hidden mounting screws.( machine screws). So will go back out and try to further take apart...
If anybody has repaired these 90’s , appreciate any tips...
Thanks
Glenn
Thanks
Glenn
