Hi Folks,
I am just curious. Does anyone use the Power Feed feature on their lathe to do threading? You might ask why bother, but I am curious for a "Universal" Threading chart/spread sheet I have been investigating. What are the issues and problems? Is it ever useful? Clearly you give up the thread dial as you are not using the lead screw. There may also be some looseness or backlash, but is this really an issue for fine threads where you have gotten a running start? Clearly an "Electronic Lead Screw" would make this a moot point, but if you do not have one....
By "Universal" I mean any of a large number of lathes. The thread chart would include all of the change gears etc in all combinations. Clearly on many lathes there are far more possible "custom" threads that could be made. Does anyone make custom threads or ever run into odd ball threads that they need to make? If and when I finish it I will post it for folks and I am trying to decide if I should include the additional threads that you could possibly make using the Power Feed rather than the lead screw 1/2 nut.
Dave L.
Dave L.
