- Nov 21, 2015
- 226
I have an Atlas MFC mill that was converted to a vertical mill. Power feed for the X-axis table was gone. I have purchased the gearbox, and correct table feed screw. I also have a small variable speed power source (1/16 HP Bodine motor and reduction gearbox, plus a 4 sheave step down pulley set) to drive it, however, I will need to construct a drive shaft to deliver the power. Here is the question. I am using square tube, and square bar stock to make the sliding shaft itself, but am debating on what universal joints to place on both ends. I have priced Lovejoy universals, and experienced moderate sticker shock. I am considering using standard 1/2" drive socket universals, as I can buy 2 of those at 1/3 the price of the Lovejoy ones. In either case, I will be welding the universals to the ends of the shafts.
Thought? Comments? Suggestions?
