Well, its time for me to build a Power Drawbar(PDB) for the PM-728VT. It really sucks using the two wrenches. I like the idea of holding the tool as I release it. I also want a foot pedal to operate the PDB.
This may not be a fast build, but I will share all the information I have and look forward to all my questions being answered. Thanks in advance.
So far I have watched a ton of videos. Franco, CNC4XR7, CRUDCNC, etc. Lot of good information out there.
I have ordered the same 3 stage air cylinder that Tormach uses, CQ2100 X 12-3. Really easy to order. Should be here towards the end of the week. Contact White Wu at email address: ppyz8@xinyipc.com.cn. He creates an order line for you at Alibaba. You can use Paypal so there is not any credit card concerns. It was $267 shipped by FedEx. If you just buy off Alibaba you pay alot higher price.
So to start, I needed to create a drawing for the threaded bolt holes on top of the mill. I only need the holes on the top right to hold a bracket. On this bracket would be standoffs going up to the plate on the air cylinder and an air valve mounting on the side of the mill. I also have to keep the encoder mounting in mind. More on that later.
I did the drawing and 3D printed a template to see if I the drawing was correct. Not a perfect fit but it will work for building the PDB. The bolt holes line up, but may adjust the fitment of angles, bigger diameter around pulley, and such. I'm a beginner to advanced at Fusion360 so my drawings suck. They will get better over time. I'm a Computer Programming Manager with a passion to machine parts and build things, electronics, cars, etc.
Stay tuned, more to come.
