- Dec 31, 2016
- 166
I recently purchased a Power Draw Bar for my PM 949 mill which is a TS style with a cam on top to engage and disengage the direct drive when changing speed ranges. I had talked to Matt at QMT via E-mail awhile back and he sold and recommended purchase of the Maxi Torque-Rite unit which I ultimately purchased from KBC not Matt as I'm in Canada and getting the unit from Matt is a significant amount more hassle and the price was the same from our Local KBC store. At any rate the unit should work but I've no real idea how to attach the power head.
Problem I have is that everything I see describes mounting it on a TV style machine. With the TS style head it simply ain't as simple. Has anyone done this and if so what are the tricks. I'm guessing I need to turn (or purchase?) a spacer to go from the top of the bearing housing to the base of the Power Draw bar unit. Even so not sure exactly where attach as I don't think drilling and attaching to the lock nut is a good idea as the ongoing reversing torque from the power head will likely loosen the bearing lock nut with time and the ring that the nut threads into is pretty marginal in radial thickness to attach to.
Any one who's been thru this I'd appreciate hearing how you did it.
